SketchUp Pro 2018
Hardware: Intel i7-4770CPU @ 3.40GHz. Running twin NVIDIA GeForce GT 640’s DDR3 128-bit.
Issue: Push/Pull no longer works. I can lay down a simple rectangle and can’t pull it into a cube. Nor can I push and remove the hard edge of a rectangle into a soft radius.
I edited the post.
No model sharing is needed as I can’t even pull up or down even the simplest square. There is nothing complex going on. Push/Pull simply grabs the object and moves it up or down. Shift, Ctrl, and Alt have zero effect on it.
Thank you for your reply.
Create a simple cube in the web version, download it and open it in the desktop version and see if it’s editable. And the shape is not in a group or component?
You have tried both keyboard shortcuts and using the various icons?
If I understand correctly You don’t need to uninstall but rather find the installer in your downlaoads folder then right click it and install as administrator and then select repair on the prompt. Others would know more than I.
You don’t need to uninstall. Login as you usually would to the computer. Right click the installer and choose run as administrator, confirm permission for windows to be modified, then choose “repair” when prompted. That way any toolbar settings or extensions won’t be modified.
