The oldest driver that provides adequate OpenGL 3.0 support with Intel HD Graphics 4000 is version 10.18.10.4061. First try your computer manufacturer for latest drivers as the manufacturer custom tweaks the base Intel drivers to work on their machines.
For more relevant info, just use the search term “intel 4000” in this SU forum.
I have a different problem, my sketchup launches but shows a white screen when running it on my Nvidia GTX 880M (OpenGL Version 4.5.0).
It just starts normally on my Intel Iris Pro Graphics 5200 (OpenGL Version 4.3.0).
I want to run Sketchup on my Nvidia because on my intel it’s a bit sluggish now and then.
check with the support tool of the notebook maker or on their support webpages if there is a customized graphics card driver dedicated to you notebook model.
Hi, were you able to get SketchUp to run? I have similar error message when I try to run Sketchup. I have the exact same config as yours. My Old ThinkPad runs SU 2017 without any trouble, and that didn’t have any discrete graphics.
It was working for me, but it was way too slow. Just wondering if you were able to fix it.
Thanks Dan. I still see that my sketchup is running very slow, and SU2017 checker still lists the same issue as not enough memory. I have a proprietary plugin at my work place which runs very slow, and that’s what has forced me to look at these issues in detail. Anyway, I’ve asked those guys who create the plugin to look into it. I will keep you guys posted.
Hi Dan, I get that error message for Graphics memory. I checked with above mentioned method, and I could see both Intel 530 and NVidia 960M listed there as display and render only respectively.
For anyone with the problem where they run SketchUp 2017 Checkup and they receive a message saying their graphics card has a 1mb of graphic memory and SketchUp requires 256mb, try going into SketchUp-Window-Preferences- and uncheck “use fast feedback”. It seems to work for me. I still get the above message in Checkup, but the programme isn’t running awful anymore! Also when I check “use fast feedback” again, the issue of Sketchup Make 2017 running slowly returns. I use a 16gb GeForce GTX 980m graphics card on my laptop.
The two things are “apples and oranges”,… (ie, they are unrelated.) The Checkup error is actually a Microsoft “msinfo32.exe” error, which Microsoft acknowledges but apparently has no care to fix.
The proof is that after doing what you suggest Checkup still sees the same error (because Microsoft has not “magically” updated the “msinfo32.exe” file.) It’s internal bug still exists, and Checkup sees the same erroneous information regarding the graphics RAM.
This indicates you may have a bad video driver. When was the last time you updated the driver ?
There was a new driver released just two weeks ago:
And also verify that SketchUp is using the Nvidia GPU and not the Intel integrated GPU. Window > Preferences > OpenGL > Details…
Verify the “Renderer” is the Nvidia driver.
To be honest, I have no idea what they mean. I’m new to SketchUp and can’t even use it yet.
24th Feb is when I last updated my graphics driver, so doubt it was a bad video driver and I only installed SketchUp yesterday (like I’ve mentioned above, I haven’t learned the programme yet). SketchUp is using the Nvidia GPU and not Intel integrated GPU.
Whatever the reason, I don’t have the problem anymore…unless, that is, when I check “use fast feedback” option and the issue of SketchUp running slowly and lagging comes back.
Have you tried different anti-aliasing settings (Window > Preferences > OpenGL)?
With the latest NVIDIA driver (378.66, 02-14-2017) I can’t detect any performance difference in SU 2017 with FF turn on/off (using 0x, 2x, 4x, and 8x MSAA) on a Win 10 system with an NVIDIA GeForce GTX 950M graphics card.
In these forums there were a bunch of posts a week or two back from users that got an (automatic?) driver update and had to roll back their driver to keep SketchUp working with Windows 10. I wonder if anyone has the actual driver version number to post here as a warning…
