I installed every single app (30+) and ran SU2017 after every installation, as soon as I installed Duet, SU2017 stopped working. I took a system image every 5 app installs so the recovery wasn’t too painful.
Doing a clean boot to test and ultimately isolate an interferring app is quite a bit less work. It disables all unnecessary startup programs except Microsoft stuff and your video driver. If SU works OK in clean boot mode, just compare a list of background apps that run in clean boot mode against a list of background apps in normal mode for possible suspect apps and go from there.
@mchandler, you may want to look into a program @sygad1 found (troubleshooting described above) that interfered with SU17 called Duet…
