With no 3rd party plugins installed at all (both Plugins folders renamed on Mac), I still see the same slow timing.
OSX 10.11.4 SketchUp 2016.0.19913
Adam
Adam
OSX version?
Sketchup version?
Same result with no plugins installed.
I’ve also tried SketchUp 2015 and get the exact same hang.
However, Sketchup 2014 works fine.
Adam
Also, just to sanity check, you are using my modifed script, not the original. Its important to generate mesh normals to trigger this.
module MeshPerformanceTests
def self.run(iterations = 1)
iterations.times {
self.run_test
end
def self.run_test
puts "\n#{self}"
model = Sketchup.active_model
definition = model.definitions.first
Sketchup.active_model.start_operation("MeshTest", true)
Sketchup.active_model.set_attribute(:meaning, :life, 42);
puts "\n> Testing model.entities:"
result = self.time(model.entities)
puts "> Time: #{result}s"
puts "\n> Testing definition.entities:"
result = self.time(definition.entities)
Sketchup.active_model.commit_operation
end
def self.time(entities)
start = Time.now
num_triangles = 0
num_edges = 0
entities.grep(Sketchup::Face) { |face|
mesh = face.mesh(7)
pos = mesh.points
uv0 = mesh.uvs(true)
uv1 = mesh.uvs(false)
tris = mesh.polygons
edges = face.edges
edges.each {|e|
e.start.position
e.end.position
num_edges += (e.visible? ? 1 : 0)
tris.each {|t|
for index in 0...2
pos[t[index]]
mesh.normal_at(t[index]+1)
uv0[t[index]]
uv1[t[index]]
end
num_triangles += tris.count
puts "#{entities} contains #{num_triangles} triangles"
Time.now - start
end
end # module
snap on OSX, but M1 on SU i.e. 16.1.1451
using TT’s last set true then false
> MeshPerformanceTests.run(10, true)
#<Sketchup::Entities:0x007faa21fab090> contains 58569 triangles
> Time: 0.477028s
#<Sketchup::Entities:0x007faa1efb3658> contains 58569 triangles
> Time: 0.478291s
> Time: 0.410597s
> Time: 0.40697s
> Time: 0.409842s
> Time: 0.424444s
> Time: 0.41269s
> Time: 0.410703s
> Time: 0.465524s
> Time: 0.414035s
> Time: 0.415552s
> Time: 0.413223s
> Time: 0.418112s
> Time: 0.414684s
> Time: 0.416838s
> Time: 0.4124s
> Time: 0.414979s
> Time: 0.411131s
> Time: 0.409765s
> Time: 0.410698s
10
> MeshPerformanceTests.run(10, false)
> Time: 0.411382s
> Time: 0.405142s
> Time: 0.408692s
> Time: 0.41025s
> Time: 0.414318s
> Time: 0.41526s
> Time: 0.556313s
> Time: 0.52759s
> Time: 0.407285s
> Time: 0.40442s
> Time: 0.406831s
> Time: 0.405581s
> Time: 0.410829s
> Time: 0.408164s
> Time: 0.460376s
> Time: 0.41219s
> Time: 0.411045s
> Time: 0.405952s
> Time: 0.406767s
> Time: 0.404471s
10
SketchUp 2016.0.19912
Windows 10
Runs MeshPerformanceTests fine without set_attribute, hangs with set_attribute
Why are you running / testing on an obsolete version ?
I tested on … Win7 64-bit, SketchUp 2016.1.1449 64-bit
I ran this script you posted in post:
http://forums.sketchup.com/t/1000-times-slower-api-call-between-in-a-group-and-free-geometry/22442/13
as modified by Thomas in the following post:
http://forums.sketchup.com/t/1000-times-slower-api-call-between-in-a-group-and-free-geometry/22442/14
However, I missed his initial statement in post:
http://forums.sketchup.com/t/1000-times-slower-api-call-between-in-a-group-and-free-geometry/22442/12
… and then his test code in post #14
has just mesh = face.mesh
So, I change that line to: mesh = face.mesh(7)
and run with modify argument false
ThomThom::MeshPerformanceTests.run(10)
#<Sketchup::Entities:0x0000000aad1100> contains 58569 triangles
> Time: 0.724042s
#<Sketchup::Entities:0x0000000048b908> contains 58569 triangles
> Time: 0.769044s
> Time: 0.685039s
> Time: 0.635036s
> Time: 0.677039s
> Time: 0.638037s
> Time: 0.771045s
> Time: 0.630036s
> Time: 0.71104s
> Time: 0.641036s
> Time: 0.69104s
> Time: 0.628036s
> Time: 0.830048s
> Time: 0.630036s
> Time: 0.653037s
> Time: 0.629036s
> Time: 0.655037s
> Time: 0.617035s
> Time: 0.676039s
> Time: 0.615035s
10
ThomThom_Mesh_Test.rb (1.1 KB)
Running with the modify
argument true
just locks up SketchUp.
Here is an example “attribute write within undo” test that does NOT lock up SketchUp:
Dan_AttribUndo_Test.rb (1.0 KB)
module Dan; end
module Dan::AttributeUndoTests
extend self
DICT = self.name
# Dan::AttributeUndoTests.run(10)
def run(iterations = 1)
run_test(iterations)
end
def run_test(iterations)
puts "\n#{self}"
start = @running = Time.now
iterations.times {|i|
"Set Attributes",
true, # disable the UI updates
false, # just let subsequent operations handle the chaining
i > 0 # true except for the first iteration
model.set_attribute( DICT, "loop #{i}", (Time.now - @running).to_s )
@running = Time.now
duration = Time.now - start
puts "\n> Test duration: #{duration} secs Total."
puts " > loop #{i}: #{model.get_attribute( DICT, "loop #{i}")} secs"
puts()
@running = nil
end
end
Dan’s v1, eventually resolved…
> Time: 966.112729s
> Time: 0.671304s
You mean the one wrapped in the ThomThom
module ?
And it took 16 minutes+ to finish, on your Mac, with the modify argument set true
OK good, so it is a bug that is reproducible.
@DanRathbun, its not an exercise in finding a way around it, so much as giving Trimble a repro so they can dig in and find out what the heck is going on that takes so very long.
Ach! I’d missed the face.mesh(7)
in my last test. When added back in I can finally reproduce this. (In fact, it was so bad that I gave up waiting for it…)
I’ve logged this internally as SU-33848. Need to dig into the debugger and profiler to figure out what goes on here.
I think that eventually you’ll flood the undo stack - as the intermediate operations you create with making operation transparent counts towards the 100 max limit.
Thanks TT!
May be worth capturing in the bug report that weirdly, if you ENABLE GUI updates in the Undo transaction, there is no significant delay/hang - which is the complete opposite you’d expect.
Yes - that’s a good point. A quick initial stepping through the debugger shows that internally when you get face.mesh(7) within an operation that modifies the model there is an internal flag that force update every time vertex normals are requested. Still unclear why this appear to manifest in the root and not when not modifying the model.
I’m guessing here, but maybe modifying the model turn that flag on and the disable_ui
preserves preserves it across the operation. While without it the flag get reset.
Yes and these are read-only calls to extract geometry info. Why is it being marked as a modification?
Entertaining the idea of exposing this flag to allow developers to choose to enable or disable it, how would ya’ll think it best be implemented ?
a Geom::PolygonMesh::update_vertex_normals=
class boolean setter method ?
an extra (new) argument to the Sketchup::Model#start_operation
method ? *
an extra (new) argument to the Sketchup::Face#mesh
method ? *
( * : … and while at it rewrite argument handling to allow hash arguments. )
… or some other way ?
It doesn’t - it’s the attribute you set. That’s an undoable operation. Without that there is no slowdown. So the flag is caused by an actual model change (even though it’s not visual geometry).
This shouldn’t really be needed to be exposed. It’s an internal implementation detail for which we clearly have a really bad performance bug.
