Hi everyone,
anyone noticed in 2017 Layout transparent background is missing? I mean when I export top view I have white background behind my model. In 2016 it used to be transparent. Anyone know how to fix it?
Hi everyone,
Did you look in the SketchUp Model inspector window under the Styles tab? It’s in the same place it’s always been.
Hi Dave,
thanks for quick reply!
It doesn’t do anything for a background it still stays white, not transparent. See screenshot. Do you get transparent background?
I do get a transparent background. Try rendering in Hybrid instead of Raster.
Hybrid has white background also. Only vector seems to fix that, but it is not an option for me. Maybe it got something to do with sketchup style? Can you send .skp file the one which makes transparent background. I will try to open it on my machine.
Upload the LayOut file. If you don’t want to make it public, click on my name and then “Message” and send it privately.
Here it is.
I also tried to use default sketchup templates both for sketchup and layout and still get white background
TEST Layout.layout (1.9 MB)
TEST Sketchup.skp (740.8 KB)
Hmmm… I just selected the scene in the Scenes list and the background went transparent. I wonder why it doesn’t do that on your Mac. Graphics card issue?
Then it must be something to do with either mac version or graphics card.
here is my mac details. I don’t know much about graphic cards…
Then it must be graphics card… what is yours John?
mine GC is a very old amd in a mid 2007 iMac…
There are other threads about Sierra having some GC issues and one for submitting your card details to help resolve the problem…
It seems to be specific cards rather then Sierra itself…
john
I have the same problem and have been told that it’s a bug with people running an AMD Radeon R9 graphics card. Cant wait for them to fix the bug because it really lengthens my work time when trying to export with transparent background. I have to erase each background in photoshop first before I can continue…
Lets hope sketchup team fix this soon. It’s not the only problem I’ve found. Here is what I get when exporting to layout. This problem is not consistent. Sometimes it’s there sometimes it’s not…
This one has already been discussed here and traced to an issue with the drivers for some graphics card drivers. The fix for this will have to come through Apple.
See: Black areas showing up in 2017 Layout viewport - #27 by Marc
I know this thread goes way back but just coming across this as I’m new with the sketchup workflow and this seems to ‘fix’ the issue - shaded with textures is the style that works - the others still produce a white background. Thanks for raising this option as a workaround!
I cannot find a single Style on Mac 2021 Layout that has a transparent background.
My go to “Shaded with textures” now has a white background in 2021?
Does anyone know where "shaded with textures, transparent background went?
Cheers
You should be able to set up any style with a transparent background in LayOut if you have no sky or ground enabled. None of the styles in SketchUp have a transparent background. You’ll untick the box in the Styles section of the SketchUp Model panel to enable the transparent background in LayOut.
If you’re having difficulty making it work, upload your LO file and share it so we can help you out.
What version of SketchUp and LayOut are you using? Please complete your profile.
Hi Dave,
Thank you.
I was struggling at first because I didn’t have the backgrounds box ticked but I still had a white background.
I turned it on and turned it off again and now it’s working fine!
Thank you very much for the fast reply!
