sirtet
December 30, 2016, 11:32am
1
I have a Model, in which i have a section cut on the terrain, to show the terrain as a single line only in an elevation plan:
But in LO, this section cut line only shows in raster mode…
I thought i saw that working before with vector and hybrid too, but i’m not sure.
An answer on the post here
Hello,
this is my first post here. I’m using SketchUp Pro 8 and I’m having some export issues. I wanted to export a section cut of a isometric view of my model for further edition in AutoCAD, but the cut lines are missing. All the other lines are there, exept for the cut lines.
I tried exporting to PDF and LayOut and the cut lines aren’t there either. In LayOut I could see them in raster mode, but they disapeared after I switched to vector mode for DWG export.
Here are PDF files with the isom…
Suggests that these cuts are not visible unless i do a ‘Create Group from Slice’…
Is that true?
DaveR
December 30, 2016, 11:58am
2
It could be any of several things. Could you share the LO file?
DaveR
December 30, 2016, 1:58pm
4
I asked for the LayOut file. Could you share that instead of the SKP file?
sirtet
December 30, 2016, 3:31pm
5
Note to self: Read before posting…
The full LO file is 30mb and my uplink slooow, so i created a test-file, which shows the same behaviour:
But not entirely:
The back-view shows parts of that terrain line in vector, all in raster, and all if rotated away from the standard back view…
DaveR
December 30, 2016, 3:54pm
6
The link goes to a page indicating the file has been removed.
Anssi
December 30, 2016, 5:39pm
7
I sometimes have missing section edge lines (and other lines) in vector rendered LayOut views too. I have seen this in all versions of LayOut. I haven’t found a way to produce this consistently. For a scene of mine I used the Place Camera tool to make sure the camera was outside the model, but that didn’t help even though this seems to be some kind of clipping.
Anssi
