When I draw a line and label it 10" long it shows up on the screen as tiny dot. Window-Zoom has only 2 settings, once in and once out, and neither makes any real difference in viewing. Camera-Zoom has some zoom settings but they don’t seem to just make the tiny dot on the screen any bigger…
I just want what I am drawing to appear on the screen big enough to work with…?
Thank You! That did the trick… It makes that 10" line fill the screen. Just what I wanted. That way if I am drawing to a 18x24" page, I can draw an 18x24 box and Voila! …a page to work with! Is this Sidney BTW?
Nope, I’m a Steve! By the way, if you have a typical size model you work with, you can draw something that size, zoom extents on it, delete it, and then save the result as your default template. Thereafter your default template will open already zoomed to that size.
Thanks Steve… Sidney is a landscape architect in town… Your help is very much appreciated. I think the next questions will revolve around printing from my I-Mac to the Canon MX 88w Ink Jet printer. Typically I draw parts up full scale, and take them to the shop… My initial test were not successful, although the page set up and printer options are limited…
This is a very common question. It is easier using Layout, which is part of the Pro version of SketchUp, but with a bit more effort can be done using SketchUp Make. This topic links to several tutorials on how to proceed:
Steve… stumbling around, I discovered that taking a screen shot (cmd-shift-4 on the mac) of the drawing seems to reproduce it 1:1… go figure… Then I can PDF and reproduce, or e-mail it, or whatever…
Can other Mac people duplicate @SecondWind screen shot technique of printing-to-scale? I would like to add this to the SketchUp Sage’s print-to-scale tips.
Steve… I tried it again with another drawing and I think I just lucked out…kinda close, but not really. Maybe somebody more talented than I can work this into a science, or there is another way to print full scale details…
I was surprised at the screenshot technique, as a screenshot just captures pixels it doesn’t know anything about physical size. As you say, probably just a lucky accident! If you export from SketchUp as a 2D pdf, I believe you can get exact scale from something that knows how to print pdfs though.
I use a page template that is 8.5x11 and if I hold the screen shot cursor “about” 1/4" from the edge of that, and select it, it is pretty darn close…highly scientific…
So, your thinking to save as PDF and then print? Worth a try!
I tried Exporting to PDF and printing from there, but it does not print 1:1, as in being able to use a measuring tape on the drawing. So, after a bit of trial and error I included some guides on the SketchUp drawing, in the form of 2 squares in the corner. If I set the Screen shot cursor on the inside corner and drag to the other inside corner, it produces a drawing that is pretty darn close to being measurable, within 1/32 anyway. I attached the file, because hopefully a picture is worth a 1000 words…?
Speaking of 32nd’s… Can SketchUp get closer than a 16th? I would love to get down to a 64th, especially for hole drilling sizes… Armature Top Plate 1~.skp (99.1 KB)
It sounds to me like you’re working too hard. And maybe trying to run before you know how to walk.
First, in SketchUp you can adjust the precision of your drawing and dimensions under Window>Model Info>Units. If you’re working in fractional inches, set the units to Fractional and set the precision to 1/32 or 1/64. I prefer to work with precision at 1/64" because it makes it easier to find incorrect dimensions.
After you create an appropriate scene in SU and send it to LO, set up the scale correctly and export to PDF. Keep in mind there are scale settings in Acrobat/Reader that impact how large the PDF prints out. It may be that your drawing didn’t print to scale because you had the incorrect scaling option selected in Acrobat or Reader.
SketchUp works to high precision internally, but depending on the settings in Window->Model Info->Units it may display rounded off values and may snap lengths to a specified interval.
One thing to be aware of if you work with small parts and close tolerances is that SketchUp has a “clean up” operation that merges vertices when they are closer together than about 0.001". This can cause loss of edges and their associated faces when you have tiny details such as edges in arcs or circles. The workaround is to scale the model (or a ComponentInstance) up by some factor, do the drawing of the small features, then scale back down afterward.
Looking at your file, the model is purely 2D. Why not extrude the plate to its proper thickness and have a 3D model that you just happen to be viewing flat-on in parallel projection? That’s what SketchUp is really meant for, and it would take seconds to achieve. There is a text question in the model “can you bevel edges at 20.5 degrees?”. Not clear who that is addressed to, but if you make the model 3D the answer is “certainly!”, and then it will show your true intent.
Here’s an example of what I meant (I took a guess whether the bevel would be in or out - no big deal to fix if I went the wrong way). I also made the plate a Group so that the various dimension lines don’t carve it up and added layers to manage visibility and redrew the circle at exactly 1 1/2 radius by typing the value. The initial view I saved in the model isn’t a straight top view, so wouldn’t be what you would want to print for making a template, but don’t you think it shows your intent more clearly?
First of all, as the “New Kid on the Block” I want to thank all of you for your help. Forget who it was who said I was working way too hard and trying to run before I could walk, but the comment was spot on. Now that the crush of this project is off, and is being cut with a laser for later assembly, I can take some time and actually learn this program, starting from the beginning. I remember there were some video tutorials, and that seems like a good place to start…Yes?
