I’m using a script to draw some solids using faces and push-pull. It appears there is a strange and un-expected corner case behavior. A positive push-pull distance is normally drawn in a positive Z direction (for faces in a plane parallel to the XY plane). But, when the faces is actually in the XY plane (Z=0), that
direction is reversed. I’m guessing the face and back face are swapped.
The following code file demonstrates the behavior. Simply open the Ruby console and load the code from a file. The red cylinder shows the “problem”. Is this intentional ? Does it make sense for some reason ?
=begin rdoc
SketchUp strange behavior (from Ruby API).
A cylinder can be drawn by drawing a circlular face, then
performing a push/pull to a specific height. This can all
be done from a Ruby script. But there seems to be an odd
corner case in the way the API works. The direction of the
face seems to depend upon the Z coordinate of its origin.
If this coordinate is 0, the direction is reversed.
=end
=begin rdoc
Method: cylinder
Creates an empty group in the entities for the active model,
then adds cylinder entities to that group. The cyliinder has
a vertical axis.
Arguments:
* origin 3dPoint at center of bottom face of cyliner
* radius radius of the cylinder
* height height of the cylinder
* material color of the cylinder
=end
def cylinder( origin, radius, height, material )
group = Sketchup.active_model.entities.add_group
entities = group.entities
up = Geom::Vector3d.new(0,0,1)
# Call methods on the group's entities collection to draw a
# circle perpendicular to the specified axis
circle = entities.add_circle origin, up, radius
face = entities.add_face( circle )
face.material = material
face.back_material = material
face.pushpull height
return
end # method
=begin rdoc
Main
3 identical cylinders are drawn to show how the direction of
the push/pull differs when the face is at Z=0. The Red cylinder
is the oddball.
=end
# 3 cylinders will be drawn. They are parametrically identical
radius = 10 # radius of all cylinders
height = 50 # height of all cylinders
# The cylinders are spaced out in the XY plane (they all have
# vertical axes). The only difference is the polarity of the
# Z coordinate of the origin.
spacing = 4 * radius # XY spacing between cylinders
center = []
center[0] = Geom::Point3d.new(1*spacing,1*spacing,-10)
center[1] = Geom::Point3d.new(2*spacing,2*spacing, 0)
center[2] = Geom::Point3d.new(3*spacing,3*spacing, 10)
# Draw the 3 cylinders
cylinder( center[0], radius, height, "Green" )
cylinder( center[1], radius, height, "Red" )
cylinder( center[2], radius, height, "Green" )
