Round two adjacent edhes on rectangular rod (SU2014)
I want to design a box made from 25x25mm rectangular rods. Along the side and bottom I can do a simple arc and push/pull to round the edges. How can I round the two adjacent sides on the corner pieces please?
I just want the top to be curved - not the whole corner rod.
Use a 45 degree vertical face to slice a copies of rounded 25mm cube(s).
See: Creating a groin vault with a raised center
Thanks Dan – I think I know what you’re saying but I’m a beginner J
Regards
Howard
This message seems to have come from Sqn Ldr Howard Toon’s private email account.
“No matter how hard you push the envelope, it will remain stationery”
Try this:
-Gully
Thanks Gully
That’s how I started to look at it but I want the basic rectangular rod shape to be retained – something like this:
I followed Dan’s hint and got this double-rounded top but couldn’t get that top curve smooth – there’s a definite ridge there. L
Regards
Howard
Use the Follow Me tool. Omit the rounded corners and simply run the tool around the perimeter. It’s exactly like using a router to cut the same corner radii.
As a rule, it’s better to get your geometry completely constructed before applying colors so you can see what you’re doing.
-Gully
If a smooth tangency is what this is about, be sure to look for double-tangent inferencing, which is magenta, when you draw the profile of the corner radius:
-Gully
