I’m using Fredo6 Round Corner extension but I don’t get the result I’m looking for.
I get some not filled corners and I’d like to know why it happens and how to fix it.
@DaveR, wow, it worked, what kind of trick is .01.?
I mean … I don’t understand it. Edit: I had used ‘,’ instead of ‘.’ because of my Input Language Keyboard
You’re enter a scale FACTOR. If you scaled up by a factor of 2, you would scaled down by a factor of 0.5, right? If you made it twice as big, you’d need to make it half as big to get it back to the right size.
If you scale it to make it one hundred times bigger, you need to use 1/100 to get back to the original size.
OK. comma it is.
As I’ve said, the Dave Method means you don’t need to scale down.
Here is another example of the Dave Method, specific to round corner.
This enables you to use round corner successfully on a 1mm cube.
After editing you simply delete the large one.
[quote=“lehang, post:16, topic:48205, full:true”]
Why i can’t install it?
[/quote] Assuming you mean Round Corners ??
Download its RBZ [from the EWH or SketchUcation > PluginsStore] and use SketchUp’s built-in installer on that file…
