I have used SketchUp for some time and I am using 2016 now. I am Color blind and 2017 is has a solution to that problem. But the Actual “SketchUp.exe” file is missing.
I have 64 system, Windows latest version of installer, NET Framework 4.5.2, and Visual C++ Redistributable for Visual Studio 2015.
When you installed SketchUp 2017 from its installer exe file I suspect that you did NOT you do it in the proper way…
Select the installer’s exe file icon.
Right-click > context-menu
Run as administrator
This method will install SketchUp properly,
If SketchUp is already installed, then selecting the Repair option might fix thins, without the necessity of an uninstall/reinstall ?
Trying to install SketchUp by double-clicking its installer or just ‘run’ will NOT work - it MUST be done in the recommended [only] way !
