I have drawn a framework that I intend to make from timber. I have clad it with a 6mm thick panel and filled it with a white fill. When zoomed in close all is fine when I zoom out I can see the framework behind the 6mm panel.
Its also worse when I input into Layout as you can see some of these framework lines through the panel.
I have hidden geometry turned off, and I believe I have tried every other option.
From a distance with thin geometry things just behind can bleed through. You need to use layers and assign what is behind to a layer that you can turn off. Don’t try to do this by using the ‘Hide’ option.
Sorry have now mucked it up, I drew on the panels, grouped them and tried to create another layer, now I can turn off the panels visibility fine but if I now turn off the frames the panels disappear as well, its as if I have the panels on both layers ! Is this possible ?
You didn’t wait long enough for the upload to complete! Most likely you have got a nested component associated with a different layer than the one containing it. This can cause confusing visibility issues.
Make sure all your raw geometry (i.e., edges and faces) remain on Layer0. Only groups and components should be assigned a layer other than 0.
You can check the layer your raw geometry is on by entering the context of the relevant group (double-click to edit enters its context). Select a face or edge and take note of the layer in Entity Info.
The only difference it would make if you were to upload the model is you’d have us fellow users to perform these simple checks for you, but there’s no reason you can’t do it yourself.
