Boas!
Eu realizei o download de sketchup em versão do Brasil/Português, mas quando instalei o programa ele ficou em Inglês… O que posso fazer??
Good(day)!
I realized download SketchUp version of Brazil / Portuguese, but when I installed the program it was in English … What can I do ??
Even if you have downloaded the correct language version, SketchUp will be in English if your operating system language is not the same as the SketchUp language version. There is a way to force the language by adding a command line switch to the shortcut you use to start SketchUp. The instructions are hiding somewhere in this forum…
So for you it would be:
INCORRECT - SEE CORRECTION, NEXT POST
"C:\Program Files\SketchUp\SketchUp 2015\SketchUp.exe -lang=pt-BR"
You can modify the desktop shortcut “Target” field, to add the language parameter.
Old topic but since I struggled a lot myself to change the SU language I’ll share my results here.
The target field of the shortcut should actually NOT be:
but:
"C:\Program Files\SketchUp\SketchUp 2015\SketchUp.exe" -lang=pt-BR
with the language parameter after the quotation mark.
The equal sign also seems to be optional.
