we develope our on CAD/CAM.
Our costumers use our collada Export to get 3D-model in Sketchup
In the attached file, Import ends by 75%. I cannot find an error and other Viewers can the Project Import completely.
I hope anyone can help me collada.zip (1.4 MB)
Best Regards
Bernhard
The DAE file imports quickly and SketchUp gives no error report.
Here are the import settings I used.
There are other things missing in the collada file too.
I notice the green material in your image. There is no green material in the collada material folders.
the Image is from our costumer. if I export project with my pc I donāt have this texture.
If our costumer exports the texture is allready in material Folders.
My problem is, that I donāt get an error message or error log, too.
I used same options to import in SketchUp.
Do you not have several faces reversed ?
Either in your DAE-exporter processing, or in the original SKP [which we donāt have]
There should be no blue faces seen in Monochrome modeā¦
Hi,
I have removed all components with possible reversed faces.
The components still lost after import.
I donāt know what could be wrong with the components
I use Windows 8 64 bit, I have changed all textures to one and then exported. same result. My Problem is, that I donāt know which solid make the Problem. I thought a sketchup developer could debug the Import and see the Point, where Import ist aborted. I think the Problem is in model, too. But I donāt know where or what component
Since we donāt have the original SKP itās hard to say what is different about the missing parts.
If the SKP is purged and fixed under Model Info > Statistics is the DAE any better when imported into a SKP.
Using MeshLab to " clean + repair" the op model:
24 degernate faces , 28095 duplicate vertcices , 17195 folded faces => must have a clean model before too many conclusions are drawn?. Final result can be filter application sequence dependent so more work needs to be done
Here is one for you.I used Su 8 to to import the dae file and then saved as a skp file. I then opened in su 2015 and it appears the components are there+. you need to checkcolladatest.skp (2.9 MB). Saving as su2015 and then open in it ok Steve has been AWOL in all my skp files?
I can confirm this.
I imported the DAE into SketchUp v8.
It gave an error - āunable to verifyā¦sure?ā - but it did import OK anyway.
ALL of the missing parts seem to be there.
I also tested it in all newer SketchUp version [v2013 onwards], and there are no messages AND bits are missing.
It seems that newer DAE importer is less forgiving ???
Trimble need to look at the importer to see whatās changed - v8 can cope as can several 3rd party importers, so what is different in >=v2013 ? I have reported it directly to themā¦
Hereās the v8 result, showing the previously missing elements.
If I export from v8 as dae then import it to 2015 works ok , Steve still AWOL and some textures not applied. Shortly after SU 8 release I tested it with the Kronoās group test model of astronaut and moon buggy and was OK but have not done such test since to other versions assuming Trimble knows how to run regression test.
Thank you, to spending so many time to my issue.
If I understand it right, in Version SKP 2013 the Import runs without missing parts and it seems, that Skp 2015 have a difference by importing dae?
[quote=āb_wensauer, post:18, topic:8598, full:trueā]
Thank you, to spending so many time to my issue.If I understand it right, in Version SKP 2013 the Import runs without missing parts and it seems, that Skp 2015 have a difference by importing dae?
[/quote] Import of the problem DAE into SketchUp v8 works OK - there is a ācheckingā warning, but it imports OK.
BUT all newer SketchUp versions miss out parts, without any warnings.
