To use solid inspector you need to make the model a group or component, suggest component.
Turn on hidden geometry that will give you better visibility of model.
When I run solid inspector it reports some errors it can fix others it cannot. Those are mainly non 2 manifold errors, which are most likely around the eyes which you will have to fix. See following link
