Hi all,
We are writing an extension on Ruby for SketchUp 2015 x64. This extension will work with our COM object. The COM object is .NET library.
.NET simply calls Windows Forms
MessageBox.Show();
but this lines closes SketchUp. While debugging I get next exception message
Exception of type 'System.ExecutionEngineException' was thrown.
and SketchUp is closed. If I call the same method as COM object from .NET simple console application all works fine.
Have you met with this kind issues before? Maybe you know a better way to call .NET functions from Ruby extension.
Any help is appreciated.
Best regards, Vladimir
You can use the Ruby wrapper for the system messagebox function:
[url]Homepage | SketchUp Developer
msg = "Some text message we display to user."
UI.messagebox( msg, MB_OK )
icehuli
3
Hi Vladimir,
You need to call the MessageBox.Show(); within another thread.
for example:
Dispatcher dispatcher = Dispatcher.CurrentDispatcher;
Thread thread = new Thread(() =>
Thread.CurrentThread.CurrentCulture = new CultureInfo("en-US");
lock (windowLock)
_mainWpf = new SODMainWindow(this, dispatcher);
_mainWpf.Closed += (sender2, e2) =>
_mainWpf.Dispatcher.InvokeShutdown();
_mainWpf.Show();
System.Windows.Threading.Dispatcher.Run();
