In this topic:
At least two people have now tried to use the ScaleTool attribute of Dynamic Components in order to simplify things like allowing a user to scale the width and height of a picture frame component without distorting stock used for the frame. It seemed to me that it should be simple by restraining the possible scaling using the ScaleTool (see: this). Alas, this is not the case!
Here’s a couple of GIFs. This one shows a single component (Inner) with scale restrictions contained within another component (Outer). As you can see, it seems to be working as I expected:
Now edit the outer component and add a 2nd instance of the inner component (note that the part where you can’t see what I did in the context menu - I did an explicit redraw of the outer component):
I searched the Knowledge Base to see if anything there documented that this behavior is expected and found nothing. Thus I report this as a bug!
I call this buggy behaviour: Parent Components don’t honor scaling restrictions in Child Components - unless there is only one child!
