If I select an object and press alt, on the Mac, and drag the object around I have a copy.
If I select an object and press alt, on the Mac, and use the cursor keys to move the object around I have a No copy.
Is this intended? The plus on the move cursor icon is there.
I really like to use the cursor keys to move an object to the right spot, but want to start with the cursor keys from the beginning if there is little replacement wanted for the copy.
I don’t know whether it is intended or not but I’m certain it isn’t a bug. There’s an alternative work flow which will let you do what you want. Select the object. Hit Command-C to copy it, Command-V to paste it and then use the cursor keys to move the copy. you’ll have to select the object with the mouse anyway but this keyboard method makes it simple to move things and maintain alignment.
