Blueprint Style in Layout
Hi, In the layout_sketchupModels.mov there is a Blueprint style does anyone know where I could find it or download it
Thanks
Carlo
The style of a model should be defined in one of your SketchUp scenes which can then be exported into a Layout file. Your model can have various styles portrayed and each of these can be shown in the scenes that you place into Layout.
In SU, go to Windows->Styles; then in the Styles dialog box that appears, click on “Assorted Styles” just below the “Select-Edit-Mix” tabs and then select the Blueprint style in the box as shown. Once the style is identified in a specific SU scene, save the model and then export the scenes you want to see to Layout. Your Layout window will be set accordingly.
If it were any bigger…
Thanks
Carlo
